michael100 Posted June 29, 2008 Share Posted June 29, 2008 Hi, Can anyone tell me if I need to remove the viscous fan in order to fit a new water pump or can the fan be left in situ. Thanx Quote Link to comment Share on other sites More sharing options...
K88 MUD Posted June 29, 2008 Share Posted June 29, 2008 Left in place as the fan is not connected to the water pump. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted June 30, 2008 Share Posted June 30, 2008 It's very easy to replace the pump on the 300TDi engine, but be careful when undoing the bolts - they have a habit of siezing. Refer to this thread - it involves removing the pump. http://forums.lr4x4.com/index.php?showtopic=7547 Les. Quote Link to comment Share on other sites More sharing options...
freeagent Posted June 30, 2008 Share Posted June 30, 2008 I'd take the pump housing off and replace the P gasket behind it aswell.... Quote Link to comment Share on other sites More sharing options...
Mark Posted June 30, 2008 Share Posted June 30, 2008 I would second freeagents comment, particularly since I didn't replace my p-gasket when I did the pump, and now it is leaking like a leaky thing, so I have to have it all apart again. I think I took the viscous fan off anyway, just to give room to work. It's not difficult to get off or on again afterwards. Mark Quote Link to comment Share on other sites More sharing options...
pinny Posted June 30, 2008 Share Posted June 30, 2008 I would second freeagents comment, particularly since I didn't replace my p-gasket when I did the pump, and now it is leaking like a leaky thing, so I have to have it all apart again.I think I took the viscous fan off anyway, just to give room to work. It's not difficult to get off or on again afterwards. Mark as others have said replace the p gasket as it will give you grief not too hard to do i put sealant on mine when i put it back toghether chris Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted July 1, 2008 Share Posted July 1, 2008 Well, you don't have to remove the water pump to do the P gasket, but you might as well do it while you are mucking about on the front of the engine. To answer the original question, as I have the correct spanner I always remove the viscous fan when working on the front of the engine, I don't think you can change the water pump if it is on. If needed, you can make a viscous spanner out of bit of old leaf spring. Just make a 32mm slot in it with an angle grinder. Quote Link to comment Share on other sites More sharing options...
Thys Posted July 1, 2008 Share Posted July 1, 2008 I would second freeagents comment, particularly since I didn't replace my p-gasket when I did the pump, and now it is leaking like a leaky thing, so I have to have it all apart again.I think I took the viscous fan off anyway, just to give room to work. It's not difficult to get off or on again afterwards. Mark To add to Mark's comment, I did two things wrong: 1. Bought a Britpart water pump, and after three months the pump screeched like a pig! 2. Did not replace the P-gasket and now a leak..... I would also recommend removing the viscous fan. As a precaution I cut a piece of chip board that fits on the face of the radiator, and I use that board whenever I work on the front of the engine. Radiators are very expensive here in South Africa. Quote Link to comment Share on other sites More sharing options...
