jimmy_neutron Posted July 14, 2008 Share Posted July 14, 2008 I think i know the answer to this one but want to double check. I decided to replace the glow plugs cos they are about 4 years old. I replaced no4 cos its easiest and it looked ok. No3 however was covered in unburnt engine oil. Why ?? No 1+2 are still to do cos it started to pour down and i wimped out. Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted July 14, 2008 Share Posted July 14, 2008 It's duff. the "clean" ones have burnt all the oil/diesel off of themselves, but the duff ones won't. stick a multimeter across it, you'll find it's open circuit. Quote Link to comment Share on other sites More sharing options...
jimmy_neutron Posted July 14, 2008 Author Share Posted July 14, 2008 It's duff.the "clean" ones have burnt all the oil/diesel off of themselves, but the duff ones won't. stick a multimeter across it, you'll find it's open circuit. oooohh ... Thats not the answer i was expecting. Interesting thought. I thought the answer would be valve stem oil seals goosed on no.3 but not on no.4 , so a head off job. It was definately engine oil and not diesel. Quote Link to comment Share on other sites More sharing options...
mmgemini Posted July 14, 2008 Share Posted July 14, 2008 Exactly a Jim has said. An oily heater plug is a knackered heater plug. Take them all out. Replace with a new set. Test the old ones. Keep the good ones incase you just need one again. mike Quote Link to comment Share on other sites More sharing options...
jimmy_neutron Posted July 14, 2008 Author Share Posted July 14, 2008 Exactly a Jim has said. An oily heater plug is a knackered heater plug.Take them all out. Replace with a new set. Test the old ones. Keep the good ones incase you just need one again. mike Thanx both. Quote Link to comment Share on other sites More sharing options...
