Guppy Posted July 14, 2008 Share Posted July 14, 2008 Hey guys, just a quickie... Had a bit of a play in a quarry at the weekend, got a wee bit filthy with wading and whatnots. Anyway - the truck is letting out a very audible moan when turning the steering wheel and steering is noticeably stiffer on the right. I've given everything a thorough blast with the pressure washer and a visual inspection shows nothing amiss. Checked the fluid and there's no water ingress or leakage. Haven't checked the belt yet but it was replaced about 4000 miles ago so should be ok? Do I just need to break out the grease gun and go crazy on the linkages? Quote Link to comment Share on other sites More sharing options...
Les Henson Posted July 14, 2008 Share Posted July 14, 2008 Check the belt tension. Groaning/stiffer steering is usually down to this. Les. Quote Link to comment Share on other sites More sharing options...
Guppy Posted July 15, 2008 Author Share Posted July 15, 2008 Left the house this morning to find a very ominous red patch on the driveway... it would appear I have a leaky PAS pump. It obviously didn't like swimming... It's leaking from the input shaft just behind the belt pulley - Can I obtain new seals or is it simply a replacement job? Quote Link to comment Share on other sites More sharing options...
