110landy Posted July 14, 2008 Share Posted July 14, 2008 hey there need some advice, i have an oil leak in my rear hub its just started, any idea what it may be? and will it be easy enough to fix for a new landy owner? cheers Liam Quote Link to comment Share on other sites More sharing options...
Les Henson Posted July 14, 2008 Share Posted July 14, 2008 Is the leak on the outside/centre of the wheel, or coming out of the brake drum or onto the disc? Les. Quote Link to comment Share on other sites More sharing options...
110landy Posted July 15, 2008 Author Share Posted July 15, 2008 yes the oil leak is coming from the outside/centre of the wheel Quote Link to comment Share on other sites More sharing options...
Les Henson Posted July 15, 2008 Share Posted July 15, 2008 It could be the drive flange gasket behind these 5 x 17mm bolts, or perhaps the oil is coming out of the hub cap itself. To get at the gaslet - remove the hub cap, remove the circlip and shims, then undo the bolts and the flange will come off. A new gasket is about 10p Les. Quote Link to comment Share on other sites More sharing options...
smacsor Posted July 15, 2008 Share Posted July 15, 2008 Hi Les, On my vehicle the whole of the drive flange is wet with oil and the hub cap itself is saturated although it's not yet contaminated the brake drum. Is this still likely to be the gasket or something more tricky. Don't want to start something I can't see through! cheers, Simon Quote Link to comment Share on other sites More sharing options...
