zim Posted July 15, 2008 Share Posted July 15, 2008 Hello, Ok... i've been reading the forum for ages, but never posted ! I'm about to get some fittings to make up some breathers, but am not 100% sure on what threads they are ? Can someone confirm : Defender Axel (1/4 bsp ?) 200 tdi Crank & Bell housing The gearbox (LT77 / R380) and transfer boxes are on banjo bolts, but just out of interest what thread are they as well ? And finally what is the normal size to drill and tap the Warn 8274's to install a breather on them ? Thanks Gordon Quote Link to comment Share on other sites More sharing options...
gsr341 Posted July 15, 2008 Share Posted July 15, 2008 [quote name='zimsoundz' date='Jul 15 2008, 10:21 AM' post='288 The gearbox (LT77 / R380) and transfer boxes are on banjo bolts, but just out of interest what thread are they as well ? And finally what is the normal size to drill and tap the Warn 8274's to install a breather on them ? Thanks Gordon as far as i know the axels are 1/8bsp , as are the gearbox transfer are the same , and ive done my 8274 the same , all using 6mm nylon pipe , that way you allways have spare on the truck you can rob for other parts (my ARB,s are the same) Quote Link to comment Share on other sites More sharing options...
zim Posted July 15, 2008 Author Share Posted July 15, 2008 The gearbox (LT77 / R380) and transfer boxes are on banjo bolts, but just out of interest what thread are they as well ? And finally what is the normal size to drill and tap the Warn 8274's to install a breather on them ? Thanks Gordon as far as i know the axels are 1/8bsp , as are the gearbox transfer are the same , and ive done my 8274 the same , all using 6mm nylon pipe , that way you allways have spare on the truck you can rob for other parts (my ARB,s are the same) thanks. so axels, gearbox & tfr box are all 1/8 bsp what about the engine ? i'm running a v8 and can only find 1 breather on that just above the fly wheel, but need to get some goodies for a diesel truck as well Gordon Quote Link to comment Share on other sites More sharing options...
zim Posted July 15, 2008 Author Share Posted July 15, 2008 Addition to my previous reply, i've found by searching the engine wading plugs are 1/4bsp. G Quote Link to comment Share on other sites More sharing options...
freeagent Posted July 15, 2008 Share Posted July 15, 2008 yep, 1/8 bsp, if you do a search on ebay for 1/8 bsp you'll find a company selling push fit 1/8 bsp elbows for 54p, and 4mm hose for 40p per metre... i bought 16 quids worth yesterday, enough to do the whole truck.... Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted July 15, 2008 Share Posted July 15, 2008 yep, 1/8 bsp, if you do a search on ebay for 1/8 bsp you'll find a company selling push fit 1/8 bsp elbows for 54p, and 4mm hose for 40p per metre... i bought 16 quids worth yesterday, enough to do the whole truck.... Do you have a link to them? i've got £15 sat in my paypal account burning a hole.... Quote Link to comment Share on other sites More sharing options...
Se7enUp Posted July 15, 2008 Share Posted July 15, 2008 And adding to the fun - can anyone post up a list of what parts I'd need to fit breathers to a TD5. (axles, gearbox, transferboxe etc) Also roughly how much tube I'd need to buy - I'm planning to route the pipe up to the top of a snorkel. Any info would be great as I SO don't want to pay £50 for a "proper" wading kit!!!! Quote Link to comment Share on other sites More sharing options...
freeagent Posted July 15, 2008 Share Posted July 15, 2008 Do you have a link to them? i've got £15 sat in my paypal account burning a hole.... http://stores.ebay.co.uk/Pegasus-Industrial-Wholesale Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted July 15, 2008 Share Posted July 15, 2008 Cheers....will get ordering later Quote Link to comment Share on other sites More sharing options...
zim Posted July 15, 2008 Author Share Posted July 15, 2008 Cheers....will get ordering later this is who i was going to use, seem cheaper at a glance. http://stores.ebay.co.uk/Jims-Engineering G Quote Link to comment Share on other sites More sharing options...
freeagent Posted July 16, 2008 Share Posted July 16, 2008 sorry to pull this thread a bit off topic... but can i get to the breather connections on my gearbox and transfer box in order to change the banjo fittings for my new elbows, with uot pulling up the plate under the centre consol in my 300Tdi disco...??? Quote Link to comment Share on other sites More sharing options...
