joe1 Posted July 15, 2008 Share Posted July 15, 2008 Thought I'd ask as people have obviously already done this (lots of times!) on these conversions and I dont want to reinvent any wheels...... Whats the consensus on the best and EASIEST place to put the Disco air box. I've got the disco power steering complete with ZF reservoir, there is no aircon(!), so the airbox can either mount on n/s inner wing, or on the air/con mounts or even in the 300tdi position. But currently I only have the disco standard trunking from air box to turbo so this limits placement - if it goes elsehwere what trunking would you use? ( I've seen some 60mmID eberspacher heater ducting that looks like it may do some of the job) On the intake side of things there will be no snorkel so am looking for some ideas about a neat way of finishing off a standard intake as well...... Quote Link to comment Share on other sites More sharing options...
joe1 Posted July 16, 2008 Author Share Posted July 16, 2008 ....example of eberspacher ducting is here.... http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...A:IT&ih=018 Quote Link to comment Share on other sites More sharing options...
lrfarmer Posted July 16, 2008 Share Posted July 16, 2008 i mad pipe to keep it were it normaly gos on the TD Quote Link to comment Share on other sites More sharing options...
joe1 Posted July 16, 2008 Author Share Posted July 16, 2008 Thanks Tim only prob is that I dont have any TD bits to hand (base vehicle was a NA ) Any other ideas out there....... Quote Link to comment Share on other sites More sharing options...
Sean Posted July 16, 2008 Share Posted July 16, 2008 ....example of eberspacher ducting is here....http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...A:IT&ih=018 youd be better off wrapping tin foil around a toilet roll than use that stuff - it's just got no real strength CAF hose is what you want http://stores.ebay.co.uk/Auto-Performance-...1QQftidZ2QQtZkm Quote Link to comment Share on other sites More sharing options...
thirstybeast Posted July 18, 2008 Share Posted July 18, 2008 Hi My air filter brackets came off the 200 tdi disco that the engine came out of and fitted to the lh wing on the bracket the coil was on Quote Link to comment Share on other sites More sharing options...
JST Posted July 18, 2008 Share Posted July 18, 2008 can you reuse the 2.5na filter? i am running same as Tim a td filter with a 200 disco, in same place are original TD one. or mount it 300tdi style. Quote Link to comment Share on other sites More sharing options...
thirstybeast Posted July 19, 2008 Share Posted July 19, 2008 Hi Joe another pic taken today showing the pipes to turbo and manifold. Quote Link to comment Share on other sites More sharing options...
