Fern Posted July 17, 2008 Share Posted July 17, 2008 The story began when I lost my keyfob. So right now I'm opening my car with an emergency code which I enter with a key. I've decided to install aftermarket alarm (which offers remote radio key, remote start and other nice features). Meanwhile I was trying to deactivate alarm ECU just taking out the wires from it. But when I lock the doors alarm activates (I don't know how it does). This is the first question: How to uninstall alarm in Disco I? Sure in disarmed state. How to remove alarm ECU? What makes alarm sound when ECU is switched off? And the second question. As I said I want to install by myself aftermarket alarm (Alligator 875RS), did anybody done that by himself? What are the problems? Any directions? How to control spider unit or it should be removed? Quote Link to comment Share on other sites More sharing options...
drkwack Posted July 17, 2008 Share Posted July 17, 2008 The story began when I lost my keyfob. So right now I'm opening my car with an emergency code which I enter with a key.I've decided to install aftermarket alarm (which offers remote radio key, remote start and other nice features). Meanwhile I was trying to deactivate alarm ECU just taking out the wires from it. But when I lock the doors alarm activates (I don't know how it does). This is the first question: How to uninstall alarm in Disco I? Sure in disarmed state. How to remove alarm ECU? What makes alarm sound when ECU is switched off? And the second question. As I said I want to install by myself aftermarket alarm (Alligator 875RS), did anybody done that by himself? What are the problems? Any directions? How to control spider unit or it should be removed? Hi, a lot of us have been down the same road, Bogmonster has done a listing months ago, try putting in a search for alarms on the forum, you will be surprised by what comes up. If I remember correctly the spider has'nt got a lot to do with the alarm ( some body will correct me if I'm wrong), you can get away with leaving the disco's alarm on and not using the original key fob this saves a lot of head scratching and throwing of hammers around the garage, best of luck Quote Link to comment Share on other sites More sharing options...
Fern Posted July 18, 2008 Author Share Posted July 18, 2008 Hi, a lot of us have been down the same road, Bogmonster has done a listing months ago, try putting in a search for alarms on the forum, you will be surprised by what comes up. If I remember correctly the spider has'nt got a lot to do with the alarm ( some body will correct me if I'm wrong), you can get away with leaving the disco's alarm on and not using the original key fob this saves a lot of head scratching and throwing of hammers around the garage, best of luck Sure I had searched the forum before I made a topic, the answers that I found do not cover my questions. Quote Link to comment Share on other sites More sharing options...
drkwack Posted July 19, 2008 Share Posted July 19, 2008 Sure I had searched the forum before I made a topic, the answers that I found do not cover my questions. done a quick recap, the alarm ecu is in the passenger footwell small box green in colour with "lucas 10 AS " on it hope this helps. Quote Link to comment Share on other sites More sharing options...
Fern Posted July 21, 2008 Author Share Posted July 21, 2008 done a quick recap, the alarm ecu is in the passenger footwell small box green in colour with "lucas 10 AS " on it hope this helps. thanks, this helped:) actually i have switched off something, but not alarm box:) there is a black box near ECU with similar pinouts. ok, now I found the alarm ECU, and spider also. I have hardwired the pins on spider, which are 10-6, 8-4 according to BogMonster. Now I can release "the official BogMonster Bypass + (version 1.1)", for V8 motors you should also hardwire pins 2-3 which go for fuel pump. This works on mine ride. BogMonster should add this to his article in TechArchive. Quote Link to comment Share on other sites More sharing options...
Fern Posted July 21, 2008 Author Share Posted July 21, 2008 I have hardwired the spider but when I disconnect the alarm ECU the engine does not start!!! HOW TO DISCONNECT THE ALARM does anybody know that? Quote Link to comment Share on other sites More sharing options...
Fern Posted July 22, 2008 Author Share Posted July 22, 2008 I HAVE DONE IT!!! I have successfuly removed the alarm ecu from my disco. To remove it I had to hardwire pins 10 and 11 on C274 connector (hardwire ground with Starter Solenoid Relay). This mights be also useful for somebody, that's why I do this post. Now I'm completely ready to install aftermarket alarm. Quote Link to comment Share on other sites More sharing options...
