Igol Posted July 18, 2008 Share Posted July 18, 2008 I've noticed my 97 disco has developed a dreaded intermitant fault. The rev counter starts flopping around all over the place when I've my foot on the accelerator and drops to zero when its off. Obviously a fault, unless its doing its bit for global warming and shuts down when I take my foot off. Is there going to be a bit expensive problem heading my way or am I looking at a nice simple 'clean contact 'x' up and it'll be fine'? Quote Link to comment Share on other sites More sharing options...
Pete Attryde Posted July 18, 2008 Share Posted July 18, 2008 If it's a TDI . The rev counter is driven from the alternator, so I suspect that either the connection on the alternator is dodgy or the alternator it's self is on it way out. If it's a V8 I can't help. Quote Link to comment Share on other sites More sharing options...
Igol Posted July 18, 2008 Author Share Posted July 18, 2008 Its a tdi and you can bet that it wont be the simple cable needs a tweek. Just need a break in the rain and I can get out and see whats loose...or isnt Thanks Quote Link to comment Share on other sites More sharing options...
lrfarmer Posted July 18, 2008 Share Posted July 18, 2008 hi my 200tdi was doing it but when i disconected the alternator to do some welding when i put it back together it stoped doing it and has been fine since may so you could try all the connections first but it could be the alternator playing up but as long as it's charging it not likely to be gone Quote Link to comment Share on other sites More sharing options...
Andy J Posted July 18, 2008 Share Posted July 18, 2008 I've noticed my 97 disco has developed a dreaded intermitant fault. The rev counter starts flopping around all over the place when I've my foot on the accelerator and drops to zero when its off. Obviously a fault, unless its doing its bit for global warming and shuts down when I take my foot off.Is there going to be a bit expensive problem heading my way or am I looking at a nice simple 'clean contact 'x' up and it'll be fine'? Incase it needed further confirmation - its probably a dying alternator. Has happened at least twice to me over the last 7 years (different disco's). look on the bright side, its an early warning system that alerts you to the fact you are going to be running on borrowed time with battery charging. In most other sub standard vehicles, the charging will just die all of a sudden, probably on a dark and rainy night up a quiet road somewhere :-) Andy Quote Link to comment Share on other sites More sharing options...
yanto Posted July 19, 2008 Share Posted July 19, 2008 I've noticed my 97 disco has developed a dreaded intermitant fault. The rev counter starts flopping around all over the place when I've my foot on the accelerator and drops to zero when its off. Obviously a fault, unless its doing its bit for global warming and shuts down when I take my foot off.Is there going to be a bit expensive problem heading my way or am I looking at a nice simple 'clean contact 'x' up and it'll be fine'? hi there both my discos had this problem when I bought them just tweek the small wire on the back of the altanator worked for me.. good luck Quote Link to comment Share on other sites More sharing options...
lrfarmer Posted July 22, 2008 Share Posted July 22, 2008 himy 200tdi was doing it but when i disconected the alternator to do some welding when i put it back together it stoped doing it and has been fine since may so you could try all the connections first but it could be the alternator playing up but as long as it's charging it not likely to be gone my alternator packed up today new one on it's way Quote Link to comment Share on other sites More sharing options...
Igol Posted July 24, 2008 Author Share Posted July 24, 2008 I've cleaned up the fairly coroded terminals on the alternator and given it a quick squirt of oil and the rev counter looks like its stopped dancing. Thanks for the advice though, looks like theres a few more miles left in the alternator yet Quote Link to comment Share on other sites More sharing options...
PEASEY Posted July 24, 2008 Share Posted July 24, 2008 Isnt it good when its only time its cost you to sort things out Quote Link to comment Share on other sites More sharing options...
