trt1617 Posted July 18, 2008 Share Posted July 18, 2008 as per my post earlier on i now own a disco 300 tdi on a p plate done 76k with full history for £250 just gotta see if i can get it to fit in my 90 now! so any advise on the sbject of getting the engine and box into a 90 would be of great intrest to me thought about fixing the disco but think i like the old beaten up 90! can anyone help me with getting pics uploaded to the forum cant seem to do it. Quote Link to comment Share on other sites More sharing options...
joe1 Posted July 18, 2008 Share Posted July 18, 2008 any kind p plate for 250 is unbelievable - well done! Quote Link to comment Share on other sites More sharing options...
trt1617 Posted July 18, 2008 Author Share Posted July 18, 2008 any kind p plate for 250 is unbelievable - well done! failed on a wheel bearing a front brake pipe and the ns sill is rotten near the seat belt ancorage Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted July 18, 2008 Share Posted July 18, 2008 I think all the info you need is in the Technical Archive forum. Quote Link to comment Share on other sites More sharing options...
JST Posted July 18, 2008 Share Posted July 18, 2008 keep the LT77 from the Def and just change the defender lump over with new engine mounts. you could also fit the 1.2 disco t box for better cruising speeds/economy - depends if you tow alot/live in a hilly area take the rear disc axle off the disco and fit to the 90 (change flange i believe is all, i cant remember) weigh in the disco Quote Link to comment Share on other sites More sharing options...
trt1617 Posted July 18, 2008 Author Share Posted July 18, 2008 I think all the info you need is in the Technical Archive forum. doyou know if this covers the engine and gear box? Quote Link to comment Share on other sites More sharing options...
JST Posted July 18, 2008 Share Posted July 18, 2008 doyou know if this covers the engine and gear box? have you looked? Quote Link to comment Share on other sites More sharing options...
trt1617 Posted July 18, 2008 Author Share Posted July 18, 2008 keep the LT77 from the Def and just change the defender lump over with new engine mounts.you could also fit the 1.2 disco t box for better cruising speeds/economy - depends if you tow alot/live in a hilly area take the rear disc axle off the disco and fit to the 90 (change flange i believe is all, i cant remember) weigh in the disco the problem i have is my lt77 box hax exploded and no longer useable ie trashed beyond repair Quote Link to comment Share on other sites More sharing options...
trt1617 Posted July 18, 2008 Author Share Posted July 18, 2008 have you looked? now about to start looking. Quote Link to comment Share on other sites More sharing options...
JST Posted July 18, 2008 Share Posted July 18, 2008 you can fit the disco R380 box but you will need to fabricate a new trans tunnel for it and the gear knobs will sit further back, not sure on the mountings, you may get away with just fitting the narrower 300tdi def g box cross member - not sure. or sell it and fit a Def LT77 box or def R380 box Quote Link to comment Share on other sites More sharing options...
trt1617 Posted July 18, 2008 Author Share Posted July 18, 2008 you can fit the disco R380 box but you will need to fabricate a new trans tunnel for it and the gear knobs will sit further back, not sure on the mountings, you may get away with just fitting the narrower 300tdi def g box cross member - not sure.or sell it and fit a Def LT77 box or def R380 box if they put r380 boxes in defenders could i not get the one from the disco converted to fit? the input shaft must be shorter for a def? Quote Link to comment Share on other sites More sharing options...
western Posted July 18, 2008 Share Posted July 18, 2008 if they put r380 boxes in defenders could i not get the one from the disco converted to fit? the input shaft must be shorter for a def? only 200Tdi & earlier engine with a R380 [such as mine] have a short mainshaft & bell housing. all 300Tdi factory built Defenders have a long mainshaft & longer bell housing, in these the engine sits over the front axle & much further forward than in earlier vehicle thier engines sit behind the front axles centreline, so in effect they are mid-engined. Quote Link to comment Share on other sites More sharing options...
