Paul Whibley Posted July 19, 2008 Share Posted July 19, 2008 Hi my fuel regulator block is dripping diesel, looks a pig to change what do i have to remove to gain access and change block, cant see where the leak is, what normally happens with these. Cheers Paul Quote Link to comment Share on other sites More sharing options...
MRDIITD5 Posted July 19, 2008 Share Posted July 19, 2008 Hi my fuel regulator block is dripping diesel, looks a pig to change what do i have to remove to gain access and change block, cant see where the leak is, what normally happens with these.Cheers Paul More fiddly than difficult to change. You can either lie across the engine to reach it or if you are a short git like me stand on something Replacement is the only reliable option. Cheers John Quote Link to comment Share on other sites More sharing options...
Les Henson Posted July 19, 2008 Share Posted July 19, 2008 http://forums.lr4x4.com/index.php?showtopic=25537 Les Quote Link to comment Share on other sites More sharing options...
Paul Whibley Posted July 23, 2008 Author Share Posted July 23, 2008 Thanks for the help guys, was ok till rounded the bottom bolt off, so had to take the inlet manifold off, all sorted anyway Quote Link to comment Share on other sites More sharing options...
