dome Posted July 19, 2008 Share Posted July 19, 2008 Hello All I'm having trouble with the wipers on my 1991 RRC. The wipers didn't park at first, then they started working really slowly when I first started her up but now they have stopped working completely. I've had some of the dash off and the motor is hot to the touch so I assume something has jammed. I've removed the fuse in the meantime to save burning it out. It looks a right pain in the backside to remove the motor and/or linkage, has anyone got any tips on how to do this? Luckily my RRC isn't my daily driver so it's not urgent but Im in Scotland so wipers are a neccesity! Cheers Brian Quote Link to comment Share on other sites More sharing options...
dougstar Posted July 19, 2008 Share Posted July 19, 2008 Hello AllI'm having trouble with the wipers on my 1991 RRC. The wipers didn't park at first, then they started working really slowly when I first started her up but now they have stopped working completely. I've had some of the dash off and the motor is hot to the touch so I assume something has jammed. I've removed the fuse in the meantime to save burning it out. It looks a right pain in the backside to remove the motor and/or linkage, has anyone got any tips on how to do this? Luckily my RRC isn't my daily driver so it's not urgent but Im in Scotland so wipers are a neccesity! Cheers Brian A generous helping of Lithium grease on all the moving bits will do the trick mate Or just squirt somw WD40 in for now if you cannot access them but i,m sure you'll get in with a flexi grease gun nozzle Dougie Quote Link to comment Share on other sites More sharing options...
dome Posted July 19, 2008 Author Share Posted July 19, 2008 A generous helping of Lithium grease on all the moving bits will do the trick mate Or just squirt somw WD40 in for now if you cannot access them but i,m sure you'll get in with a flexi grease gun nozzle Dougie Whereabouts do I get squirting then? I could only make out the motor when I was going in from under the dash, how do I access the linkage/gearbox for the wipers? Quote Link to comment Share on other sites More sharing options...
Highway_Star Posted July 19, 2008 Share Posted July 19, 2008 Remove the decker/scuttle panel. Quote Link to comment Share on other sites More sharing options...
dome Posted July 20, 2008 Author Share Posted July 20, 2008 Remove the decker/scuttle panel. Bugger, thought that might be the way. Next sunny day it is then! Shame I've got a Saab to re-engine and a 106 to MOT Quote Link to comment Share on other sites More sharing options...
bishbosh Posted July 20, 2008 Share Posted July 20, 2008 Yep, etting to the wiper motor is as you expected a complete pain. Remove bonnet. Secure sprung bonnet hinges in a down attitude (harder than it sounds) I use rope through the holes in the hinge and tie it down to the chassis rails. That gives you enough room to slide the decker panel forwards so you can get behind it. Remove wiper arms and plastic shrouds. Remove decker panel. Enjoy getting to those two bolts on top of the wings and don't forget the screws into the door frame / bulkhead. Detach linkage from motor assembly. Extract motor from bulkhead. Be aware that if you go for a second hand spare (new are about £100 IIRC) that the multiplug connector varies from Disco to Rangie and of course in standard Land Rover fashion, from year to year. Refitting is the etc. etc. Hope this helps! Quote Link to comment Share on other sites More sharing options...
