Chris Rogers Posted July 19, 2008 Share Posted July 19, 2008 Trying to work out where my 300tdi is leaking oil from, ( think it would be easier to work out where it isn't coming from) Seems to be coming from the larger braided hose that comes from the turbo. Is it common for the hose to leak? or is it likely to be another component above the hose? If it is the hose, is it a big job to replace? If anyone has a part number for it too that'd be great. Thanks in advance Chris Quote Link to comment Share on other sites More sharing options...
western Posted July 19, 2008 Share Posted July 19, 2008 (edited) probably the rubber hose inside is breaking down, should be fairly easy to swap. but check the turbo oil feed pipe on top is not leaking. turbo oil drain hose is LR part ERR4895 item 12 on diagram. Edited July 19, 2008 by western Quote Link to comment Share on other sites More sharing options...
Chris Rogers Posted July 19, 2008 Author Share Posted July 19, 2008 probably the rubber hose inside is breaking down, should be fairly easy to swap. but check the turbo oil feed pipe on top is not leaking.turbo oil drain hose is LR part ERR4895 thanks western, you're a star Have had a good look at the turbo, I get a ring of oil collecting at the bottom of the hose, the top of the turbo appears nice and dry. I'll get a new hose ordered and see if that cures the problem. And see if I can work out how to fit the new one! Quote Link to comment Share on other sites More sharing options...
western Posted July 19, 2008 Share Posted July 19, 2008 the diagram will help then Quote Link to comment Share on other sites More sharing options...
