DeanB Posted July 19, 2008 Share Posted July 19, 2008 Hi, I have a 300Tdi with a dodgy rev counter, it does not work at all but i have found a small grey coloured wire just hanging at the back of the alternator with a spade connector on, can i heck as like find where it goes to! Anyone know where it goes ???????????? Dean Quote Link to comment Share on other sites More sharing options...
Discovan300tdi Posted July 19, 2008 Share Posted July 19, 2008 there should be a spade connector on the back of the alternator ,thats where the wire goes to and then hopefully your rev counter will work again Quote Link to comment Share on other sites More sharing options...
DeanB Posted July 20, 2008 Author Share Posted July 20, 2008 there should be a spade connector on the back of the alternator ,thats where the wire goes to and then hopefully your rev counter will work again Thanks for the reply, looked at the back of the alternator still cannot find anywhere for it to go, i'll have another look Dean Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted July 20, 2008 Share Posted July 20, 2008 The terminal should be marked W. Quote Link to comment Share on other sites More sharing options...
DeanB Posted July 20, 2008 Author Share Posted July 20, 2008 The terminal should be marked W. Thanks for the reply, cannot find a terminal marked W. What i have done is, cut off the connector that was damaged anyway and strip a bit of the wire, when i connect to the terminal with the thin brown wire attached with a small nut, the rev counter works but only when it is going straight to the threaded bit, i have tried trapping the wire between the nut and the casing and it doesn't work. Quote Link to comment Share on other sites More sharing options...
Richard Mills Posted July 20, 2008 Share Posted July 20, 2008 Hi There, On my 300tdi the alternator has a rectangular block with 3 nuts on it. Top is Red , main output, Middle is White, and the bottom is the grey. The spade is at about 7 O,clock on the very outer rim. I suspect it may be your spade has broken off, so you may have to put a new bit on the terminal. Good luck. Quote Link to comment Share on other sites More sharing options...
DeanB Posted July 20, 2008 Author Share Posted July 20, 2008 Hi There, On my 300tdi the alternator has a rectangular block with 3 nuts on it. Top is Red , main output, Middle is White, and the bottom is the grey. The spade is at about 7 O,clock on the very outer rim. I suspect it may be your spade has broken off, so you may have to put a new bit on the terminal.Good luck. Thanks, I will have a look in daylight i have seen the red block, then a green wire to the middle, grey block at the bottom and a spade connector just under the red box then there is just the grey wire left hanging. Thanks again Dean Quote Link to comment Share on other sites More sharing options...
