trt1617 Posted July 21, 2008 Share Posted July 21, 2008 Anyone know how to make at 300TDI run if I remove it from the vehicle it is presently fitted in. There is a black plug on the diesel pump which if unplugged stops the engine. Many thanks in advance Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted July 21, 2008 Share Posted July 21, 2008 sounds like you've got a late engine with the digital FIP... this has a 3 pin plug on the pump (as you've seen) which just controlls the cut-out solenoid. i'm 99.9% sure if you remove that you can install a "normal" 12v plunger type solenoid, which will then just need a 12v supply to run it. Quote Link to comment Share on other sites More sharing options...
trt1617 Posted July 22, 2008 Author Share Posted July 22, 2008 broke the plastic box of electrical stuff off the pump and there as even a stop solenoid fitted to the pump so just wired it up and off she went guess ill start takeing the engine and box out this weekend ready to fit in my 90 thanks Quote Link to comment Share on other sites More sharing options...
