flash42 Posted July 22, 2008 Share Posted July 22, 2008 just wondering what sought of a lift i can expect from fitting heavy duty springs to my D90. Quote Link to comment Share on other sites More sharing options...
alantd Posted July 22, 2008 Share Posted July 22, 2008 Is it lift or lack of sag B) Quote Link to comment Share on other sites More sharing options...
rusty_wingnut Posted July 22, 2008 Share Posted July 22, 2008 mine has these fitted, seems to be roughly equivalent to a 1" to 1.1/2" lift. stands as tall as a tired 2" lift. Quote Link to comment Share on other sites More sharing options...
Eightpot Posted July 22, 2008 Share Posted July 22, 2008 if you are looking at standard genuine HD springs, you wont notice a lift, it will just take a bit more weight before bouncing off the bump stops and be stiffer round corners. If your existing springs are old and tired you will prob notice half to an inch lift. Some of the aftermarket springs are heavy duty and longer - there are a couple of spring tables on here if you do a search which should help. Quote Link to comment Share on other sites More sharing options...
lrfarmer Posted July 22, 2008 Share Posted July 22, 2008 I 've just put second hand disco spring on to my 90 the front i would say is were it was when new and the back in about 1-1 1/2" higher the ride is alot harder Quote Link to comment Share on other sites More sharing options...
