bushwhacker Posted July 22, 2008 Share Posted July 22, 2008 HELP My 2 ish is up for mot my problem is I can not get the brakes up to scratch. On the 1st pedal press it goes to the floor on the 2nd it is a bit better and on the 3rd it is ok. Is it still air in the system? I had it striped down to replace brake pipes and brake shoes there is a servo on it I have used the two person method one depressing the pedal the other on the bleeders. I have used the pressurised method also a Gunison thing that works of a wheel at 20 psi. I have done these a fair amount of times and no joy. Where have I gone wrong? And is there any other method? Thanks Mark Quote Link to comment Share on other sites More sharing options...
rusty_wingnut Posted July 22, 2008 Share Posted July 22, 2008 have you adjusted the shoes? checked for leaking cylinder/master cylinder and it is possibly you could have a faulty mastercylinder. Quote Link to comment Share on other sites More sharing options...
