gibbon Posted July 24, 2008 Share Posted July 24, 2008 Hi, I've got a 200tdi disco engine in my 90, any tips on where I can find the engine number as the insurers are asking for it....!? Quote Link to comment Share on other sites More sharing options...
western Posted July 24, 2008 Share Posted July 24, 2008 on the engines right hand side, just below number 1 injector & above the cam follower side cover plate is a horizontal surface, the engine serial number Should be stamped into that area & should start with 12L like this 12L00001 Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted July 24, 2008 Share Posted July 24, 2008 And if it doesn't start with 12L you have a nicked engine (not that the other applies either). Quote Link to comment Share on other sites More sharing options...
gibbon Posted July 28, 2008 Author Share Posted July 28, 2008 Spot on! Cheers western! Quote Link to comment Share on other sites More sharing options...
110_USA Posted July 28, 2008 Share Posted July 28, 2008 Since we're on the topic, how about a 2.5L N/A Diesel? Quote Link to comment Share on other sites More sharing options...
western Posted July 28, 2008 Share Posted July 28, 2008 depends on age of engine, the serail number will be in 1 of 2 locations. 1 -- engines left side forward of exhaust front flange 2 -- above fuel lift pump on engines right hand side. Quote Link to comment Share on other sites More sharing options...
110_USA Posted July 29, 2008 Share Posted July 29, 2008 The only number I could find was. MK2/3 19928C Located in the red circle. Quote Link to comment Share on other sites More sharing options...
Matt Neale Posted July 29, 2008 Share Posted July 29, 2008 And if it doesn't start with 12L you have a nicked engine (not that the other applies either). Not quite true Jim. 12L denotes a Discovery spec. 200 Tdi. 11L = Defender 200 Tdi. There are plenty of other variations depending on the spec / fitment etc. Matt Quote Link to comment Share on other sites More sharing options...
western Posted July 29, 2008 Share Posted July 29, 2008 Yep thats it in the later serial number location,it should read something like 12J*****C add your 19928 & you have a genuine LR 2.5 naturally aspirated 2.5 litre diesel engine. try a wire brush on that area & you should find 12J at the front. Quote Link to comment Share on other sites More sharing options...
110_USA Posted July 29, 2008 Share Posted July 29, 2008 Thank you. Quote Link to comment Share on other sites More sharing options...
gibbon Posted August 16, 2008 Author Share Posted August 16, 2008 I presume that 300tdi engines are numbered in the same place as the 200tdi's, but what number series are these engines....? Also main numptee question - how do you tell the difference between a 200tdi and the 300tdi engines? Quote Link to comment Share on other sites More sharing options...
GB75 Posted August 17, 2008 Share Posted August 17, 2008 Also main numptee question - how do you tell the difference between a 200tdi and the 300tdi engines? Dead easy once you know, open bonnet look just below rocker cover on the front of the engine for large alloy cylindrical spring loaded belt tentioner if it has one its a 300tdi. Quote Link to comment Share on other sites More sharing options...
GB75 Posted August 17, 2008 Share Posted August 17, 2008 PS 300Tdi numbers are in the same place and on the defender begin with 16L. Quote Link to comment Share on other sites More sharing options...
gibbon Posted August 19, 2008 Author Share Posted August 19, 2008 Yarp! Cheers fella, its a 300tdi, should have known, doh! Also can be recognized by the position of the turbo and dipstick position! Quote Link to comment Share on other sites More sharing options...
rusty_wingnut Posted August 19, 2008 Share Posted August 19, 2008 what does the rest of the engine number on a 300tdi mean? Quote Link to comment Share on other sites More sharing options...
western Posted August 28, 2008 Share Posted August 28, 2008 what does the rest of the engine number on a 300tdi mean? he first 3 digits are the engine type code the rest is the engines unique serial/production number Quote Link to comment Share on other sites More sharing options...
