general-confusion Posted July 25, 2008 Share Posted July 25, 2008 A friend of mine has a 96 disco 300 tdi fitted with electric windows front and rear . The rears have both stopped working at the same time , i have checked the fuse which is ok , ruled out the rear window isolation switch as it has been tested and is fine but there is no power to it or either rear window switches....is it likely to be a bad solder connection on the window lift ecu in the glovebox. I need to help him quickly as he is off on holiday in a week and in this heat his kids will need the rear windows down on the journey to Cornwall Thanks in advance Quote Link to comment Share on other sites More sharing options...
PEASEY Posted July 25, 2008 Share Posted July 25, 2008 yes mate it will be the solder joint in the lift ecu its quite easy to spot if you need any help just ask,one word of warning though dont drop you screwdriver on the crash sensor underneath it nightmare to sort if you do.all things being equal it should only take about 15 to 20 mins to do best of luck. Quote Link to comment Share on other sites More sharing options...
general-confusion Posted July 27, 2008 Author Share Posted July 27, 2008 Thanks Peasey will try it this week Quote Link to comment Share on other sites More sharing options...
Underdog Posted July 28, 2008 Share Posted July 28, 2008 Read this: Disco Rear Windows Linky It should help. Quote Link to comment Share on other sites More sharing options...
general-confusion Posted July 29, 2008 Author Share Posted July 29, 2008 Lovely job all fixed , just one dry joint on the pcb and both windows working again Thanks All Quote Link to comment Share on other sites More sharing options...
PEASEY Posted July 29, 2008 Share Posted July 29, 2008 great news mate im pleased you got it sorted,well done. Quote Link to comment Share on other sites More sharing options...
