Help with a wiring question
I am currently wiring in the difflock actuator on the Nissan axles under the discovery and am using the workshop schematic below as a guide. However I do not have a 2-way switch as shown and short of a 30 mile drive to get one or wait for a delivery am stuck at an impasse. However I do have loads of various relays here and i had a brainwave that perhaps I can replace the 2-way switch with a relay (switched by a simple 1-way on-off switch that I have here) that will sent the current either way depending on whether it is open or closed. I am sure such relays exist I just need to identify them.
Anyone out there can confirm that this will work and help me find what i'm looking for. An idiot -proof wiring diagram would also be helpful!
cheers
Mark
As you can see I am useless at electrics!
Any 5 pin change over relay ( as Landy man luke^^^^^ Said) will do it or I have the exact switch you need, I'll chuck one in the truck when i come over.
Just make sure its a change over and not a 5 pin with two common outputs.
I reckon there is a way with a switch and two normal 4 pin relays, but I am struggling to work it out... I'll let you know if I get it...
Edited:
Sorry - I think that perhaps I am wrong. Unless somebody clever knows otherwise?
Yes, you need 87 and 87a, not 87 and 87b.
I reckon there is a way with a switch and two normal 4 pin relays.
You could use two normal relays and switches, you'd just have to switch one off as you switched the other on - far easier to use the proper switch :)
 Share
