wozza35 Posted July 26, 2008 Share Posted July 26, 2008 Has anyone come across this problem before,i have no dash instruments working at all ?the speedo rev counter idiot lights the lot none of them work,i have changed the complete fuse board and speedo pod but nothing it just blows the fuse anyone got any ideas??? pleeease sorry forgot to mention it is a 300 tdi bog standard but with abs Quote Link to comment Share on other sites More sharing options...
K88 MUD Posted July 26, 2008 Share Posted July 26, 2008 Would guess there is something wrong inside of your dash clocks etc. Quote Link to comment Share on other sites More sharing options...
wozza35 Posted July 26, 2008 Author Share Posted July 26, 2008 Would guess there is something wrong inside of your dash clocks etc. No i have already changed the whole pod that includes speedo rev counter etc but keep the ideas coming Quote Link to comment Share on other sites More sharing options...
K88 MUD Posted July 26, 2008 Share Posted July 26, 2008 Could try disconecting the speedo drive unit from the transfer box.....see if there is a fault in there. Quote Link to comment Share on other sites More sharing options...
wozza35 Posted July 26, 2008 Author Share Posted July 26, 2008 Could try disconecting the speedo drive unit from the transfer box.....see if there is a fault in there. Done that one as well and pulled the speedo wire all the way to the engine bay to make sure it was not worn through but keep them coming two heads are always better than one Warren Quote Link to comment Share on other sites More sharing options...
K88 MUD Posted July 26, 2008 Share Posted July 26, 2008 Does it blow fuses if you unplug the dash ? Quote Link to comment Share on other sites More sharing options...
wozza35 Posted July 26, 2008 Author Share Posted July 26, 2008 Does it blow fuses if you unplug the dash ? No it doesnt even give you a chance the fuse blows as soon as the ignition is switched on and without the dash plugged in seems like i may have to go through every instrument one by one Quote Link to comment Share on other sites More sharing options...
western Posted July 26, 2008 Share Posted July 26, 2008 sounds like a direct short in the ign controlled feed then, check the ign switch connections are all clear of each other & the terminals are fully insulated. Quote Link to comment Share on other sites More sharing options...
K88 MUD Posted July 27, 2008 Share Posted July 27, 2008 Agree with western.....could also be the ignition switch......as you said.....just have to go through everything one by one. Quote Link to comment Share on other sites More sharing options...
wozza35 Posted July 27, 2008 Author Share Posted July 27, 2008 Dont know if this is connected and if it can give any clues but the stereo seems to power up for a few seconds and then go off Quote Link to comment Share on other sites More sharing options...
