90 engine mounts
hi
iam in about to convert my 2.5 petrol 90 to a 3.9 v8 efi with a zf auto and b/w tcase. can anyone tell me if i can use the original gearbox mounting holes in the 90 chassis and weld the engine mounts to suit the new position or have i got to mount the box and engine from scratch.
thanks in advance taz
I have just fitted my 3.9 and auto in my 110, the gearbox mounts are the same as original, since my replacement chassis turned out to be a diesel one I had to change the engine mounts, so cut them carefully off the disco chassis, they fit in exactly the same location on the 90/ 110 chassis. Mine is an LT230 but if you use the mounts that came with the BW it will be the same.
 Share
