A Twig Posted July 28, 2008 Share Posted July 28, 2008 On my 300Tdi have noticed a couple of problems. Firstly when steering it feels different to my old 200Tdi. It feels like a disc sander does when you're using it really slowly on a surface (is the only way I can think of to describe it). I put this down to a tyre difference as my old 200Tdi had 205/85s rather than 235/85s I currently have But I've since noticed that on left full lock I get a real juddering through the wheel. Right full lock is fine. Is something up with the pump? Also had a couple of burning clutch incidents, usually when reversing up hills. I don't think this is much to worry about does anyone else? Finally it seems that the 300Tdi is a bit more "gutless" than the 200? Anyone else noticed this? Quote Link to comment Share on other sites More sharing options...
Eightpot Posted July 28, 2008 Share Posted July 28, 2008 If your power steering fluid is at the right level, then it sounds like you may have a problem brewing with the pump - I know the feeling you mean and with me it's always been low fluid levels so hopefuly it's as simple as that.. I think the reversing problem is basically due to the clutch plate being fairly small, a 110 is fairly hard to push up a hill and people usually ride the clutch when reversing - if you're loaded up and reversing up a steep hill you can make life easier on the clutch by dropping into low box. Can't say I've noticed a power difference between the two engines - I've got a 200 ninety and a 300 disco and they both seem pretty evenly matched considering the weight difference. Quote Link to comment Share on other sites More sharing options...
