Jason2 Posted July 29, 2008 Share Posted July 29, 2008 Anyone got a "Top Tip" on how to get the bottom bolt undone/orf on the clutch master cylinder on a 1980 109 ??????? Darn things rusty,rounded and not playing ball Quote Link to comment Share on other sites More sharing options...
Les Henson Posted July 29, 2008 Share Posted July 29, 2008 Remove the pedal box and then either try mole grips, or cut the bolt off and fit a new one. Les. Quote Link to comment Share on other sites More sharing options...
Jason2 Posted July 29, 2008 Author Share Posted July 29, 2008 Remove the pedal box and then either try mole grips, or cut the bolt off and fit a new one.Les. Cheers Les Them's bolts well rusty too but easy to get at from the inside with "Ye old Angle Grinder" Quote Link to comment Share on other sites More sharing options...
dave88sw Posted July 30, 2008 Share Posted July 30, 2008 the bolts going into the pedal box from inside go into captive nuts so try to get them out if at all possible and refit with plenty of copper grease, as for the bottom bolt, should be nice and easy once the pedal box is out, also, whilst its out, take the oppurtunity to thoroughly clean ad paint the bulkhead beneath the pedal box, cos plenty of people will have missed the filler hole and got brake fluid all down the footwells. Quote Link to comment Share on other sites More sharing options...
