Betsy Posted July 29, 2008 Share Posted July 29, 2008 I have a Marsland galvanised chassis, and unfortunately I have crushed the gearbox cross member flat on the left side where it joins the chassis. Its an easy fix, but I was thinking about changing it for a bolt on version. Anyone got any idea where I can get hold of a bolt on cross member for 109 chassis? Quote Link to comment Share on other sites More sharing options...
Les Henson Posted July 29, 2008 Share Posted July 29, 2008 You could buy a standard one and alter it so that it just bolts on. 88 and 109 are the same item. Bolt on are military items, but I can't imagine they would be difficult to get hold of - Craddockas etc might well do them. Les. Quote Link to comment Share on other sites More sharing options...
Phil Hancock Posted July 29, 2008 Share Posted July 29, 2008 88" & 109" gearbox cross members are not the same item as 88" is cranked at each end and 109" is basically straight. Quote Link to comment Share on other sites More sharing options...
Betsy Posted July 29, 2008 Author Share Posted July 29, 2008 The current (squashed) cross member is virtually straight. I'll give Marslands a ring tomorrow and see if they can supply a new galvanised item, and like you say, I can easily make it a bolt on item. Can you tell me which way the bolt on item attaches? is it via captive nuts in the main chassis rail or does it bolt right through the side rail? Quote Link to comment Share on other sites More sharing options...
minivin Posted July 29, 2008 Share Posted July 29, 2008 The current (squashed) cross member is virtually straight. I'll give Marslands a ring tomorrow and see if they can supply a new galvanised item, and like you say, I can easily make it a bolt on item. Can you tell me which way the bolt on item attaches? is it via captive nuts in the main chassis rail or does it bolt right through the side rail? The military chassis has gussets under the rails that the cross member fits into and something along the lines of either 9/16UNF or M10 bolts are fitted through Gusset at bottom left: Cross member in place: Just ignore the R380 and LT230R Quote Link to comment Share on other sites More sharing options...
Betsy Posted July 30, 2008 Author Share Posted July 30, 2008 Cheers, most useful pictures. Now I know how to do it. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted July 31, 2008 Share Posted July 31, 2008 Another option - I used a RR one on mine. Can't say if it'd fit with a standard transmission though. Quote Link to comment Share on other sites More sharing options...
Betsy Posted August 1, 2008 Author Share Posted August 1, 2008 I do have one from a Discovery, but its too big. Quote Link to comment Share on other sites More sharing options...
