bishbosh Posted July 30, 2008 Share Posted July 30, 2008 As above, could a few of you post up the dimension between your front hoop legs and the tube diameter please? (This will give the centreline dimension if you see what I mean) I am only interested in cages where the hoop goes down through the top of the wings to mount on the outrigger please. I need to work out what the correct width is so the legs fit in the gap in the wing. Thanks all! Bish. Quote Link to comment Share on other sites More sharing options...
Guest WALFY Posted July 30, 2008 Share Posted July 30, 2008 Bish Can't you get the front hoop seperately? Like you did the last time? Prob easier to buy that section. Bends in 2 different planes, hard to get right without a few mistakes? Quote Link to comment Share on other sites More sharing options...
bishbosh Posted July 30, 2008 Author Share Posted July 30, 2008 I could do, but I have a grown up helping me!!! Quote Link to comment Share on other sites More sharing options...
Guest WALFY Posted July 30, 2008 Share Posted July 30, 2008 Ahhh. OK then. Good luck. That is on the list of jobs to do on my truck and get the cage inside the wings rather than outside. If you find out the info can you do a sketch for the tech archive of the dims and angles of bends please Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted July 30, 2008 Share Posted July 30, 2008 I've got my full external P&P cage here for the 110, not fitted yet, i can get some measurements from that if it helps? (it goes down through the wings, right on the "seam" between the outer skin and the top piece) with a box section upright that bolts onto the bulkhead outrigger. Quote Link to comment Share on other sites More sharing options...
Guest WALFY Posted July 30, 2008 Share Posted July 30, 2008 That would be helpfull. What would it cost if someone took a front hoop to a fabricator and said make me 1 of these? Would they make it? Does copyright morals extend that far in the fabbing world or is it just cash speaks louder? And no that isn't a hint Jamie!!!! I'm still a way off to sorting my cage out Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted July 30, 2008 Share Posted July 30, 2008 That would be helpfull.What would it cost if someone took a front hoop to a fabricator and said make me 1 of these? Would they make it? Does copyright morals extend that far in the fabbing world or is it just cash speaks louder? And no that isn't a hint Jamie!!!! I'm still a way off to sorting my cage out 'Snot a problem if you want to borrow it and get a backup made (for safety reasons, of course, should the original get damaged or lost.... ) Can't imagine any fabricator would complain, after all, how are they to know where the template came from? you could just say "a very experienced friend of mine made it in his shed" Anyway, shout if you want to borrow... i won't be bolting it on for a couple of weeks yet. Quote Link to comment Share on other sites More sharing options...
Exmoor Beast Posted July 31, 2008 Share Posted July 31, 2008 In the absence of anything witty to say I will be usefull for a change 1502mm between tubes from outriggers to bonnet hinge level, it bends back at the screen angle from there and narrows when viewed from the front but at a lesser angle than the windscreen tapers. Need anything else give me a shout... Will Quote Link to comment Share on other sites More sharing options...
