eclipse Posted August 1, 2008 Share Posted August 1, 2008 The head gasket has blown on my 200tdi I have got it all striped down apart from one injector it is stuck in the head I have the head of the block on the bench and have tried taping it twisting it got plenty of penetrating oil on it but it is stuck fast I have left it socking over night to see if it frees up for the morning but wondered if any one out there knows of a way to remove it all the rest came out relatively easy with a twist and a tap. Quote Link to comment Share on other sites More sharing options...
vougese39 Posted August 2, 2008 Share Posted August 2, 2008 try some brake fluid as it will eat through the rust and corrosion apart from that it mite have to be a small bit of heat but you mite need to have the injector tested after that Quote Link to comment Share on other sites More sharing options...
