Trevors Posted January 10, 2006 Share Posted January 10, 2006 My 1989 Land rover 90 is not performing to well at the moment, and I do have a strange problem whenever I remove the filler cap from the diesel tank there is a huge build of pressue in the tank and it blows the cap out of my hand. I have replaced the cap but no change, anybody else had this problem? I am a bit worried it will blow the tank apart if I dont keep an eye on it. Quote Link to comment Share on other sites More sharing options...
western Posted January 10, 2006 Share Posted January 10, 2006 Is your new cap a vented one? & check the tank breather hoses aren't kinked/blocked. Quote Link to comment Share on other sites More sharing options...
Matt Neale Posted January 10, 2006 Share Posted January 10, 2006 Is your new cap a vented one? & check the tank breather hoses aren't kinked/blocked. I had exactly the same problem with mine (it's a 1989 110) when I had the original 2.5 TD engine in it. After I changed the engine over to a Tdi (and used the later Tdi filter / housing) the problem ceased. The filler cap is the original, and vented. The tank breather was all ok and clear too. I can only put it down to something in the design of the filter/leak off/return of the original setup - it's been perfect since??? Matt Quote Link to comment Share on other sites More sharing options...
gwyn lewis Posted January 10, 2006 Share Posted January 10, 2006 THIS IS QUITE A COMON PROBLEM ON 2.5 TD ENGINES THE DIAPHRAM ON THE INJECTOR PUMP HAS SPLIT AND IS CAUSING TURBO AIR PREASURE TO RELEASE INTO THE FUEL RETURN PIPE AND BACK INTO THE TANK THE DIAPHRAM UNIT IS ON THE SIDE OF THE INJECTOR PUMP NEAREST THE ENGINE 2 PIPES GOING INTO IT IT IS A SWINE OF A JOB TO REPLACE ONE OF MY CUSTOMERS ALMOST LOST AN EYE WHEN THE FUEL CAP FLEW OFF WHEN HE WENT TO FILL UP WHITH DIESEL SO BE WARNED Quote Link to comment Share on other sites More sharing options...
LR90 Posted January 10, 2006 Share Posted January 10, 2006 Well that's in impressive entrance Gwyn, welcome to the forum Quote Link to comment Share on other sites More sharing options...
Trevors Posted January 11, 2006 Author Share Posted January 11, 2006 Thanks for the advice might have a go at changing the pump diaphragm, can anyone tell me whats involved in doing this job and are any special tools required, is it pump off job?. Would this have anything to do with recent poor performance?. Quote Link to comment Share on other sites More sharing options...
sgnas Posted January 11, 2006 Share Posted January 11, 2006 The job is relatively easy. You can get the side part off the pump without removing the pump. Unless you are near a Lucas main agent, getting the parts are more of a problem! I used a diaphragm from a scrapped pump, a mate got a new one from the Lucas agent. The job is deatiled on the old forum LRA (formerly LRE) but I cannot make the search function work at the moment! As regards to performance. It'll make a small difference as it affects the amount of fuel added to compensate for the increased air available from the turbo. The other side effect (aside from tank pressure) is that after a run, and on idle fuel can be pushed up the pipe to the turbo. If it goes far enough you get a bit of fuel added to the air and the engine will race momentarily. Hopefully, as the engine races turbo pressure increases and pushes the fuel back down the pipe! LINK NOW FOUNDLINK 1 LINK 2 Quote Link to comment Share on other sites More sharing options...
Les Henson Posted January 13, 2006 Share Posted January 13, 2006 Well that's cleared up a problem that my Brother-in-law has. He has this same problem of pressurising the fuel tank and fuel also going up the wastegate actuator pipe. A local garage said the diaphragm is split and causing the problem. Thanks for confirming that Gwyn, anyone got any idea where to get a diaphragm from? Les. Quote Link to comment Share on other sites More sharing options...
gwyn lewis Posted January 14, 2006 Share Posted January 14, 2006 LUCAS FUEL PUMP DIAPHRAM ABOUT £15.00 CAN GET THEM FOR YOU IF IT IS ANY HELP OR CONTACT YOUR NEAREST LUCAS AGENT IF YOUR GOING TO REPLACE IT WATCH YOU DONT MIXE THE 2 SPRINGS UP I THINK THE WEAKEST SPRING IS ON THE OUTSIDE I RECOMEND YOU DISCONECT THE AIR PIPE FROM THE TURBO AND PLUG THEM INTILL YOU FIX THE PROBLEM HAVE SEEN THEM BLOW HEAD GASGETS ON START UP BECAUSE DIESEL HAS GONE INTO THE MANIFOLD IT COULD EAVEN DO MORE DAMAGE GWYN 01938 810298 Quote Link to comment Share on other sites More sharing options...
Les Henson Posted January 22, 2006 Share Posted January 22, 2006 Ok, My brother-in-law has just replaced the diaphragm. He got a 'kit' from his local diesel repair garage and it was £22 inc vat. The more powerful spring goes in the housing, then the diaphragm, and the weaker spring last. He did the job with the pump still on the vehicle and says thet the job wasn't too bad to do and the old diaphragm was in bits. The engine is now more reponsive and the turbo is now working correctly. One of those jobs that give you a sense of satisfaction. Les. Quote Link to comment Share on other sites More sharing options...
