stuntman Posted August 4, 2008 Share Posted August 4, 2008 Hello one and all, I know I've been asking loads of questions over a few forum but I'm now getting ready to do the engine and gearbox conversion. I have now got a rebuilt defender 110 chassis and bulkhead with the rear tub, roof, sills and b pillars all back on and repainted, I think I'm ready to drop the engine and box in. I have checked my transfer box from the original engine (V8) and is the 22D which is a 1.4, so I can use this (I belive). I'll be removing my engine and gearbox from the discovery as soon as possible, can anyone advise the best procedure for lining everything up? Do I need to use the disco crossmember? If so will it bolt straight on? What wiring do I need to take over from the disco? - Is there anything that will catch me out? I'm sure I'll be posting my questions as time goes on but I'm sure you've heard them all before! Thanks in advance everyone. Andi Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted August 4, 2008 Share Posted August 4, 2008 Are you using the original discovery main gearbox? you'll find that the gearsticks are in the wrong place if you do.... yes, use he disco crossmember (is it a 300Tdi?....if so, then the gearbox sits on that crossmember so it'll be necessary) wiring wise... does your defender bulkhead still have the old wiring loom in it? it was a V8 before? fairly easy, i'd take the loom off of the V8 lump, and graft it onto the Tdi. there's only half a dozen wires anyway, it's dead easy. you'll need to make the glowplugs work though (well, not actually that important as the Tdi will start easily without them, but it won't hurt to connect them up), Lots of good info here in Nicks Jungle with regards to the wiring of said glowplugs, and other stuff Fitting the engine: depends on how big your engine crane is. if you're using something like a forklift or a JCB or a tractor, i'd bolt the engine and gearbox up together on the garage floor then lower the whole lot in one go. If you're using a normal engine hoist, then fit the gearbox first, then drop in the engine. having no radiator or grill in the way helps things considerably. Quote Link to comment Share on other sites More sharing options...
stuntman Posted August 4, 2008 Author Share Posted August 4, 2008 Yes, I'll be using the origing discovery 300tdi gearbox and making up a new centre seat box section, I no longer have the V8 engine or box as i sold these, however I do have the wiring still in place in the truck, is this easy to change to the 300 loom? I sadly will be struggling like always with my engine crane, oh and I have a gravel drive which adds to the fun, (I've swapped 3 200tdi engine and not enjoyed a single one of them!) Can anyone help with the position of the engine mounts? will they be in the same place as a standard 110 tdi? If so can anyone help with this location? I'm planning on removing the engine mounts from the disco and grafting them out the defender so any help would be appreciated! Thatnks for the swift reply Jim. Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted August 4, 2008 Share Posted August 4, 2008 300Tdi defender engine mount positions: (same position for both sides) Quote Link to comment Share on other sites More sharing options...
stuntman Posted August 4, 2008 Author Share Posted August 4, 2008 DUDE! Thanks matey, gues what I'll be doing this week Quote Link to comment Share on other sites More sharing options...
darrenwilson32 Posted August 4, 2008 Share Posted August 4, 2008 300Tdi defender engine mount positions: (same position for both sides) hi mate if u have any problems doing the conversion pls call me on 07956315788 as i have done three of these already Quote Link to comment Share on other sites More sharing options...
stuntman Posted August 4, 2008 Author Share Posted August 4, 2008 Thanks for the help so far chaps, anyone experience any problems whilst doing this swap?? Quote Link to comment Share on other sites More sharing options...
