kindwarf Posted August 5, 2008 Share Posted August 5, 2008 Im quite a big bloke Im 6'4" and have a false left leg, and I have differculty getting my foot under the dash, the question is is there any quick fix to move the seat back a couple of inches over and above the normal adjustment. In the old mini's you could move the seat subframe rearward. Quote Link to comment Share on other sites More sharing options...
rhydgte Posted August 5, 2008 Share Posted August 5, 2008 Im quite a big bloke Im 6'4" and have a false left leg, and I have differculty getting my foot under the dash, the question is is there any quick fix to move the seat back a couple of inches over and above the normal adjustment. In the old mini's you could move the seat subframe rearward. I have seen special runners sold for defender 90/110 which allows you to move the seat back another couple of inches - however not sure if they're available for discovery's, would have thought there's something similar available.. Quote Link to comment Share on other sites More sharing options...
sotal Posted August 5, 2008 Share Posted August 5, 2008 I think the 90's are only stopped by the fact that they hit the bulkhead so the special runners lift the seat a little bit which then allows it to go back further as the bulkhead slopes away. This gives you the advantage of extra leg room in two directions, but the downside of moving your head further up, only really seems suitable for people with long legs and small bodies! The Disco should be easier to move back as there is nothing to hit into, never looked though Quote Link to comment Share on other sites More sharing options...
