beekay Posted August 5, 2008 Share Posted August 5, 2008 Evening all, Just noticed today that my dim dipped feature has failed. Normal dipped beam still works in the headlight switch position but the sidelight switch position only brings on the two small sidelights not the dim headlights. I have looked in the Haynes manual which describes a resistor limiting the headlights to sixth power when in sidelight mode. Could it be this that has failed and if so where is it? Any ideas much appreciated. 1995 300Tdi. Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted August 5, 2008 Share Posted August 5, 2008 Usually in Tdi's mounted under the RH wing, screwed to the galvanised inner wing panel. you may have better luck getting to it by removing the wing-top vent blanking plate and reaching your hand in. it's usually gold colour, about 2~3" long Quote Link to comment Share on other sites More sharing options...
western Posted August 5, 2008 Share Posted August 5, 2008 & there's a relay in this system too, have a look behind the fusebox. Quote Link to comment Share on other sites More sharing options...
