Cutting hole in floor to get to TD5 fuel pump
We have a 110 in with a leak at the top of the tank - most likely the fuel pump or the pipes. Unfortunately the tank is full so I suggested to the owner that we cut a hole in the floor instead of taking the tank out. My question is, does anyone know EXACTLY where to cut the hole?
Question: how do I make a hole in the floor without drilling through the tank by accident? That is, what is the clearance between the floor and the tank? Maybe I should use a drill with a spacer so that it can't go far into the floor?
I think you have a couple of inches clearance because there are ribs under the floor IIRC and then a space under that but yes a drill bit with a bunch of washers on so it can only just go through the floor would seem to be a sensible precaution :)
Cut with a Dremel... (Small disc grinder)
But make sure that although you are cutting Aluminium the sparks or hot cuttings do not reach the spilled fuel. This safety goes for drilling as well...
I used an angle grinder to cut the hole in mine, there is easily sufficient clearance under the floor - 50mm+. Once through the floor I was able to remove the floor 'hatch' (had to break one or two spot welds on the ali IIRC) but had to use a reciprocating saw to cut through the strengthening under the floor. Since I have a store draw in place the strength of the floor is irrelevant to me but you may wish to keep it in mind Jim - some rivets and angle iron would readily replace the strength IMHO. If you are only looking at loose connections you may get away with leaving the strengthening in place. I had to remove some so that I could change the pump.
HTH
Chris
One of these days we must get a fire extinguisher for the workshop. I think a UK H&S inspector would have a heart attack if he saw our 'workshop' :ph34r:
