Limit straps..
chrism
 Share
Im after some limit straps for my suspension, as i dont want to run the risk of ripping the end of my coilover off and was wondering if there is anywhere that makes and sells them.
I was thinking of making them myself but cant really be bothered! I would need to get the ends sewn properly to the right length anyway. I was thinking ratchet strap type material would be the stuff, and not the little ratchet straps!
Any ideas?
Chris
I may be wrong, but I would have thought that if the coil-over is strong enough to support the weight of the vehicle in compression, it would hold the axle in tension?
The danger with check-straps is them getting caught on stuff you drive over?
I suspect someone like sling & tackle would make up something for you.
Si
Im just thinking if the axle drops freely and quickly then it may put a fair shock load on it. I have just spent ages making some bits to hold the webbing, just need to find a company to send them to and have a length of strap sewn on them
You wont need them, coilovers are designed so that they can hold a significant load under tension, I dont use any with my fox airshox, after 2 years of abuse there fine.
Look at rock buggys in the states.
if the axle drops freely the rebound damping will take care of that.
What he said - they damp in both directions.
 Share
