need4speed Posted August 10, 2008 Share Posted August 10, 2008 When i bought my 4.6 crank, rods and pistons i noticed that the big-end caps were all fitted to the rods but some were fitted a different way round from the others. Now that im installing the rods/pistons i need to know the correct way round the caps are fitted to the rods. Does the bearing locating tab in the rod go to the same side or opposite side to the locating tab on the cap? Quote Link to comment Share on other sites More sharing options...
need4speed Posted August 11, 2008 Author Share Posted August 11, 2008 anyone? i know there is some 4.6 guys on here..... Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted August 11, 2008 Share Posted August 11, 2008 No idea, I'd have a search for the RAVE manuals and see what they say. Quote Link to comment Share on other sites More sharing options...
need4speed Posted August 11, 2008 Author Share Posted August 11, 2008 i tried downloading the rave manual but for some reason it wont complete the download. thought you would have known this one fridge - very disappointed.. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted August 11, 2008 Share Posted August 11, 2008 Does this help? (It was in the tech archive) Quote Link to comment Share on other sites More sharing options...
need4speed Posted August 11, 2008 Author Share Posted August 11, 2008 No mention of the rods / big-ends in there my friend... Quote Link to comment Share on other sites More sharing options...
Aragorn Posted August 11, 2008 Share Posted August 11, 2008 i'd have thaught the caps would only go on one way, they are machined as once piece during manufacture and aren't interchangeable between rods or backwards, if they've been put on backwards you should be able to see the machining marks dont line up on the bearing surface of the rod itself? Quote Link to comment Share on other sites More sharing options...
paul stage1v8 Posted August 11, 2008 Share Posted August 11, 2008 On other engines when rebuilding them they usually both go on the same side so they prevent movement in opposing directions, to be sure you could ask on here http://www.v8forum.co.uk/forum/index.php as there are several engine builders there experienced with 4.6s Quote Link to comment Share on other sites More sharing options...
