Landowner Posted August 10, 2008 Share Posted August 10, 2008 Have been told that the front disc assemblies will fit in the rear axle to convert to discs all round. How reliable is my information please. Quote Link to comment Share on other sites More sharing options...
western Posted August 10, 2008 Share Posted August 10, 2008 Fronts are to thick for the rear calipers. front disc [vented] 298mm diameter & 24mm thick [110/130] rear disc 298mm diameter & 14mm thick. [110/130] Quote Link to comment Share on other sites More sharing options...
Landowner Posted August 10, 2008 Author Share Posted August 10, 2008 Sorry, What I meant to say was replace the drums with disc set up using old front disc ass. Quote Link to comment Share on other sites More sharing options...
bishbosh Posted August 10, 2008 Share Posted August 10, 2008 How would you do that? Surely you would have every thing from the end of the axle tube out - i.e. swivel and all? Easiest and most common way of getting rear discs is to use a RRC or Disco rear axle. Plenty around and not expensive. Quote Link to comment Share on other sites More sharing options...
landmannnn Posted August 10, 2008 Share Posted August 10, 2008 Have been told that the front disc assemblies will fit in the rear axle to convert to discs all round. How reliable is my information please. Accuracy: on a scale of 0 to 100, the answer is 0. Quote Link to comment Share on other sites More sharing options...
western Posted August 10, 2008 Share Posted August 10, 2008 You can use 110 front hubs with the correct rear disks for a rear brake conversion, I'll collecting the parts to do my rear salisbury axle on my 110. Quote Link to comment Share on other sites More sharing options...
Landowner Posted August 10, 2008 Author Share Posted August 10, 2008 You can use 110 front hubs with the correct rear disks for a rear brake conversion, I'll collecting the parts to do my rear salisbury axle on my 110. Ah, best I can do is pick up the axle I've just bought (£10.50 off fleabay ) and have a look at the hubs etc. Not too worried, just bought it to recon and stick on mine but if the brakes fit the back then it's a bonous Quote Link to comment Share on other sites More sharing options...
