tedsmart Posted August 11, 2008 Share Posted August 11, 2008 Hello, If I were a good mechanic and having done timing belt changes on other vehicles other than a 300 Tdi, how long would you expect it to take to change the timing belt including the cam shaft seal crank seal idler & tensioner? the whole kit? How long would you expect it to take as long as nothing is seazed? Cheers ted Quote Link to comment Share on other sites More sharing options...
Matt Neale Posted August 11, 2008 Share Posted August 11, 2008 Hello,If I were a good mechanic and having done timing belt changes on other vehicles other than a 300 Tdi, how long would you expect it to take to change the timing belt including the cam shaft seal crank seal idler & tensioner? the whole kit? How long would you expect it to take as long as nothing is seazed? Cheers ted Allow about 2 1/2 - 3 hours to be on the safe side. I've done a 200 in about 1 1/2 hours but that was pushing it. Better to take your time and double check as you go. Matt Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted August 11, 2008 Share Posted August 11, 2008 LR stealers™ charge 3.9 hours if that is anything to go by. Not that anyone takes a 300Tdi to them anyway. The actual time it takes depends on whether some @sshole has glued on the damper or the pulley. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted August 11, 2008 Share Posted August 11, 2008 If you take your time, clean the inside of the timing cover etc, then expect about 4-hours. That's about how long it takes me and I'm a fussy bugger! Les. Quote Link to comment Share on other sites More sharing options...
