Jens Posted August 11, 2008 Share Posted August 11, 2008 My starter is beginning to act weird lately. If I leave my Defender standing for 2 days or more it won't start. Like it's stuck or something, because it doesn't even crank when I turn to key. But if I crawl under it and give the starter a good whack with the handle of a screwdriver, it starts like nothing was wrong. It have done it twice now. If it's just overnight, there is nothing wrong. Only thing I can think of, is to replace the contacts in the starter solenoid. Any other suggestions? Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted August 11, 2008 Share Posted August 11, 2008 That will do. Otherwise fit a recon unit. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted August 11, 2008 Share Posted August 11, 2008 Check this if you haven't already found it http://forums.lr4x4.com/index.php?showtopic=12088 You could always set up a hinged hammer operated by a piece of string Quote Link to comment Share on other sites More sharing options...
Jens Posted August 11, 2008 Author Share Posted August 11, 2008 Check this if you haven't already found ithttp://forums.lr4x4.com/index.php?showtopic=12088 You could always set up a hinged hammer operated by a piece of string Thanks, was looking for thread like that. Should be an easy fix! Quote Link to comment Share on other sites More sharing options...
