draper40 Posted August 11, 2008 Share Posted August 11, 2008 Hey, Currently the timing cover and ancillaries are not fitted but as I put the crankshaft bolt in to secure the damper in test runs it would not tension. I had the required washer, is this all? I thought that it might be epoxy stuck down on the thread but I was just checking I had everything else. Pete Quote Link to comment Share on other sites More sharing options...
Les Henson Posted August 11, 2008 Share Posted August 11, 2008 You should use thread locking compound on the bolt thread and damper (crank nose). If the bolt comes undone you could be looking at a new crank and damper. Les. Quote Link to comment Share on other sites More sharing options...
draper40 Posted August 11, 2008 Author Share Posted August 11, 2008 Les, I was aware of that but the bolt won't tension at all so as of yet there is no point in putting compound on. Quote Link to comment Share on other sites More sharing options...
western Posted August 11, 2008 Share Posted August 11, 2008 if it won't torque up [tension as you call it] the thread is eith dirty/damaged or even stripped. Quote Link to comment Share on other sites More sharing options...
