Les Henson Posted August 11, 2008 Share Posted August 11, 2008 I have a Butters 170amp MIG and need to hire a generator to power it for a job. Does anyone know what size generator I will need to hire? I'll only be welding 2.2mm plate on a SWB S3. Ta gents/gentesses Les. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted August 11, 2008 Share Posted August 11, 2008 Probably at least 5kva, as with most power tools you need 50-100% more power than the thing's rated for to make everything work happily. Quote Link to comment Share on other sites More sharing options...
Guest otchie1 Posted August 11, 2008 Share Posted August 11, 2008 I have a Butters 170amp MIG and need to hire a generator to power it for a job. Does anyone know what size generator I will need to hire? I'll only be welding 2.2mm plate on a SWB S3.Ta gents/gentesses Les. Take your MiG and some plate to the hire shop to suck it and see. 3KVa and up is certainly where you'll be looking. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted August 11, 2008 Author Share Posted August 11, 2008 Take your MiG and some plate to the hire shop to suck it and see. That's a joke, right? Les. Quote Link to comment Share on other sites More sharing options...
carl hurst Posted August 11, 2008 Share Posted August 11, 2008 I was looking at a Tig/mma set to run of a geny for site work and was told that not many welders like to be run from a geny, may be worth checking if yours will run ok without runing risk of damage to unit, Carl. Quote Link to comment Share on other sites More sharing options...
ciderman Posted August 11, 2008 Share Posted August 11, 2008 Les I have a 5kva Genset Arc welder/generator for site work and it will power up the 200 amp mig on 6mm plate without any issues Quote Link to comment Share on other sites More sharing options...
Les Henson Posted August 11, 2008 Author Share Posted August 11, 2008 So 5KVa - thanks chaps Les. Quote Link to comment Share on other sites More sharing options...
