pugwash Posted August 11, 2008 Share Posted August 11, 2008 Can you take a standard 110 with 33x12.5 MTs seriously off road without rubbing? Quote Link to comment Share on other sites More sharing options...
honitonhobbit Posted August 11, 2008 Share Posted August 11, 2008 No but with a little tweak here and there yes. You need the right rims or a decent set of spacers and a snadge of an arch trim Quote Link to comment Share on other sites More sharing options...
BogMonster Posted August 11, 2008 Share Posted August 11, 2008 All mine has http://forums.lr4x4.com/index.php?showtopi...20&start=20 is about 1.3" lift on the front end (Mill Services spacers and a set of Discovery rear spring isolator rings) and nothing on the back (though something is planned when I find something that is what I want!) - no significant problems with rubbing, i.e. you can occasionally hear it but nothing that does any damage. A lot of it depends on the load in the vehicle, if I was running it heavily laden it might be more of a problem, as it is, it normally just has 2 people and about 100kg of kit in the back though I have done a few trips with 4 up and the same kit in the back with not much more noise. Usually with std suspension the tyres rub on the plastic arches a bit but those just bend out of the way normally and then spring back afterwards. May be a different story if on wide offset rims or 10x15s where the tyres stick out a mile, mine are std 8x15 modulars. Quote Link to comment Share on other sites More sharing options...
