ChrisW70 Posted August 11, 2008 Share Posted August 11, 2008 Fitted a new rear axle tube to my Disco at the weekend. The replacement tube was new and bare so I have swapped everything over, all except the banjo bolt for the breather that is as the one I removed from my old axle (9/16th head) was too small for the threaded hole. Can anyone help with which banjo bolt/breather I need to get to fill the hole? Quote Link to comment Share on other sites More sharing options...
David_LLAMA4x4 Posted August 11, 2008 Share Posted August 11, 2008 Fitted a new rear axle tube to my Disco at the weekend. The replacement tube was new and bare so I have swapped everything over, all except the banjo bolt for the breather that is as the one I removed from my old axle (9/16th head) was too small for the threaded hole.Can anyone help with which banjo bolt/breather I need to get to fill the hole? Some are 1/8"bsp but some are M10x1 ( particularly some later ones )... give me a call if you are still struggling as I do both size bolts or little 90' adaptors as part of my breather kits...... Many thanks David Quote Link to comment Share on other sites More sharing options...
ChrisW70 Posted August 12, 2008 Author Share Posted August 12, 2008 Thanks for the help David, nice to speak to you earlier Quote Link to comment Share on other sites More sharing options...
