XtremeMarineInc Posted August 12, 2008 Share Posted August 12, 2008 Has anyone fit the Wolf wheels to SIII 109 axles, with the stock SIII wheel lugs? I am thinking of using Wolf wheels as a base to build beadlocks, and need to know if there are any fitment / clearance issues. Thanks. Quote Link to comment Share on other sites More sharing options...
Gazzar Posted August 13, 2008 Share Posted August 13, 2008 The steel wolf rims fit, but the turn stops on the front axle may need adjusting. The rims are wider than stock, and the offset is different, I think. You may need spacers, and you may also need longer wheel studs. G. Quote Link to comment Share on other sites More sharing options...
XtremeMarineInc Posted August 14, 2008 Author Share Posted August 14, 2008 The steel wolf rims fit, but the turn stops on the front axle may need adjusting.The rims are wider than stock, and the offset is different, I think. You may need spacers, and you may also need longer wheel studs. G. Thanks, G. ppreciate it. I don't mind spacers. I figure if DI steelies can fit under a SIII, then the wolfs probably have the same offset. Whereas DI steelies, look tucked in; these should not, as the beadlock adds 1-2" of width to the outside. I am more worried about how much it will affect any turning, so I will address steering stops later. Thanks again. Quote Link to comment Share on other sites More sharing options...
PaulMc Posted August 21, 2008 Share Posted August 21, 2008 The steel wolf rims fit, but the turn stops on the front axle may need adjusting.The rims are wider than stock, and the offset is different, I think. You may need spacers, and you may also need longer wheel studs. G. I'm selling a full set of 20 Zeus Engineering Extended Wheel Studs on eBay at the moment - Zeus Extended Wheel Studs - Wolf Wheels - Full Set 20 Paul. Quote Link to comment Share on other sites More sharing options...
