P38 Vogue Locking
GANDY
 Share
Can anyone confirm wether or not the driver's door lock contains a switch which allows the rear tailgate locking system
to work when the door is open? I'm having intermittent locking problems with my tailgate and this may be the cause.
Any inputs will be greatly appreciated.
Kind regards,
Gandy.
Kind regards,
Gandy.
you realy need to have it tested on testbook or autologic to see that all the correct inputs for the cdl are correct
The drivers door lock contains the 'master' lock if you willl which is linked to an outstation.
Within this lock there is a switch to let the BECM know whether the lock is in the locked or
open position.
You should really diagnose whether the fault is linked to the drivers door, or whether it can be
the rear tailgate actuator. The doorlock costs around £100 and takes about 10-15mins to swap
from start to finish, including taking off the door card.
Try and borrow a known good one to see if your problem persists.
 Share
