Yostumpy Posted August 15, 2008 Share Posted August 15, 2008 Can some knowledgeable person confirm whether the front / reat props are the same, same length. Is the gearbox in the same pos on a td5, or are they ALL interchangeable, ie the 300 had a longer casing to keep the props the same? thanks in advance stumpy. Quote Link to comment Share on other sites More sharing options...
white90 Posted August 15, 2008 Share Posted August 15, 2008 Same except the TD5 front is a wide angle one Quote Link to comment Share on other sites More sharing options...
reedx Posted August 15, 2008 Share Posted August 15, 2008 The front and rear props on my 110 aren't the same length . Didn't Td5 110s switch from the Salisbury to rover rear diff at some point too. Colin Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted August 15, 2008 Share Posted August 15, 2008 Well, i fitted the front prop from my (300Tdi) 90 onto my Td5 110. fitted a treat. so logic must say that the rears are the same length too. edit: Just checked microcat, and as you can see, they're the same for V8, 300Tdi and Td5. and if you're buying a (genuine) new one, it's £5 cheaper to buy a HD version!! Quote Link to comment Share on other sites More sharing options...
Yostumpy Posted August 16, 2008 Author Share Posted August 16, 2008 Thanks for that! Quote Link to comment Share on other sites More sharing options...
