briand Posted August 16, 2008 Share Posted August 16, 2008 Hi all, Looking for a technical reply and is this best place to ask? I have a 1994 V8 manual discovery with R380 gearbox ... will one from a diesil 300 fit and if not what is the difference? THANKS.. and if anyone knows of a good one (need transfer box as well!)................. Cheers, Brian. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted August 16, 2008 Share Posted August 16, 2008 Not a straight fit, the bellhousing is different and you will need to change the input shaft as well. Some of the ratios are slightly different too, but that is the least of your problems Quote Link to comment Share on other sites More sharing options...
