muddypaws Posted August 16, 2008 Share Posted August 16, 2008 Can anyone point me in the direction of a wiring diagram/instructions to splice a hotwire EFI into a series motor (lightweight 1982). I have the one for a flapper-type but I think this is a different wiring loom - is this right? Any help would be gratefully received. Many thanks. Quote Link to comment Share on other sites More sharing options...
landmannnn Posted August 16, 2008 Share Posted August 16, 2008 Not really a splice, basically all you take from the existing system is +12v. The easiest way if you are wiring from scratch is to look at the fault finding guide to see where each pin goes on the ecu. Have a look through the tech section - I am sure there is one in there. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted August 17, 2008 Share Posted August 17, 2008 This should help: You can probably run without half of it TBH. Quote Link to comment Share on other sites More sharing options...
muddypaws Posted August 17, 2008 Author Share Posted August 17, 2008 Many thanks. Just need lots of tea now when I start fitting it. Lubricates the brain............... Quote Link to comment Share on other sites More sharing options...
