Turbocharger Posted August 17, 2008 Share Posted August 17, 2008 I don't want to 'pollute' my VGT topic with extraneous questions, so can anyone give any info on the two pics below? Hard question: What're the threads in the block for these turbo oil pipes? Medium question: How do I adapt a 16mm water pipe to a 10mm water pipe? Easy question: Are these two labelled correctly? Quote Link to comment Share on other sites More sharing options...
Turbocharger Posted August 18, 2008 Author Share Posted August 18, 2008 Hard question was resolved today by the mobile pipe man. I'm still struggling with my coolant pipes though - best plan so far is to turn two 16mm -> 10mm adaptors from ally unless someone has a bright idea? Quote Link to comment Share on other sites More sharing options...
66gaza Posted August 18, 2008 Share Posted August 18, 2008 I'm still struggling with my coolant pipes though - best plan so far is to turn two 16mm -> 10mm adaptors from ally unless someone has a bright idea? You can use a soldered 15mmX10mm reducer for plumbing, available at any plumbers for less than a £1. stick a bit of 15mm in one end and a bit of 10mm in the other and Bobsheruncle. I would solder a compression O ring on either end to stop the hose pulling off. These are also made in compression fittings. Gaza Quote Link to comment Share on other sites More sharing options...
