200 tdi power steering pump
Does anyone know if a 1985 L/R 90 2.5 petrol Power steering pump and a 200tdi power stering pump are the same? I was just shipped a new pump for my 2.5 petrol by mistake and am going to swap a 200tdi in shortly. If they are the same I may keep it.
Thanks
Thanks
What bolt steering box is it?
Thanks
Is it a defender 200tdi or discovery 200tditdi you have fitted? (These two have different hose/pipe fittings)
Main thing I found is that the casing can be different, the threaded input port is usually in the same spot but the hose push on port is in different places.
Probably not worth you doing, but you can split the case off and put the correct case from the broken one on. But if you just bought it you don't want to be doing that I guess.
 Share
