The Badger Posted August 22, 2008 Share Posted August 22, 2008 Just got my gearbox replaced due to a rattle after the gearbox and before the transfer box. And a clang at the top of the clutch release. Well even though it was not the gear box.... ( know one knows what it is yet? ) Anyhow, it got serviced too, and a new oil sump. This is now apparently a standard replacement part when new Defender gets serviced. Just confirming this as I can remember there was doubt. anyhow, that's it. Quote Link to comment Share on other sites More sharing options...
Happyoldgit Posted August 22, 2008 Share Posted August 22, 2008 Just got my gearbox replaced due to a rattle after the gearbox and before the transfer box.And a clang at the top of the clutch release. Well even though it was not the gear box.... ( know one knows what it is yet? ) Anyhow, it got serviced too, and a new oil sump. This is now apparently a standard replacement part when new Defender gets serviced. Just confirming this as I can remember there was doubt. anyhow, that's it. Is this an official Land Rover thing or something undertaken at dealer level. I had mine replaced last month but had to fight for it. Quote Link to comment Share on other sites More sharing options...
The Badger Posted August 22, 2008 Author Share Posted August 22, 2008 The guy I spoke to said it was an official dealer thing... from Land Rover in Tuffnel Park ( London ) Quote Link to comment Share on other sites More sharing options...
The Badger Posted August 22, 2008 Author Share Posted August 22, 2008 sorry I can't respond any quicker because the moderators are still 'doing a good job' Quote Link to comment Share on other sites More sharing options...
Eduardo Posted August 22, 2008 Share Posted August 22, 2008 Oil sump replaced several months ago but after been hit by the shaft here in Chile also are beign replaced by the dealer The Badger: can you explain more about the gearbox problem? were covered by the guarantee? Probable cause? Thanks Quote Link to comment Share on other sites More sharing options...
BogMonster Posted August 22, 2008 Share Posted August 22, 2008 sorry I can't respond any quicker because the moderators are still 'doing a good job' Eh? Quote Link to comment Share on other sites More sharing options...
The Badger Posted August 23, 2008 Author Share Posted August 23, 2008 Oil sump replaced several months ago but after been hit by the shaft here in Chile also are beign replaced by the dealerThe Badger: can you explain more about the gearbox problem? were covered by the guarantee? Probable cause? Thanks Well not really as I don't think there was a problem with the gear box, the dealer just replaced that , and the oil sump, the rattle still happens but im convinced it's not the gear box anyhow, and the dealer does not know what it is, check the image as the arrow show where the noise comes from and I and to stupid to know what this bit is. And it was all covered by the warranty, had it's yearly service too. Quote Link to comment Share on other sites More sharing options...
Tony Hillerby Posted August 23, 2008 Share Posted August 23, 2008 Just had the 110 in for its first service and the dealer replaced the sump without asking. Possibly LR telling the dealers to just do it. Doubt if the dealer would do it of their own accord as the dealers seem to have to contact LR for anything warranty wise and that takes ages. Tony Quote Link to comment Share on other sites More sharing options...
Eduardo Posted August 23, 2008 Share Posted August 23, 2008 Well not really as I don't think there was a problem with the gear box, the dealer just replaced that , and the oil sump, the rattle still happens but im convinced it's not the gear box anyhow, and the dealer does not know what it is, check the image as the arrow show where the noise comes from and I and to stupid to know what this bit is.And it was all covered by the warranty, had it's yearly service too. Strange, Must be somethig particular in your motor. The part that you mentioned is the transmission extension housing (sorry if the translation is not good, but I have the workshop manual in Spanish) that holds the extension shaft. By the way, I just check the GTR and appeared (Jul, 21st) a Special Service Message for the Puma motor regarding a heavy noise during the start in the motor. Here it is: Models LD - Defender Title 2.4 Puma Engine Knock Noise. Last Modified 21-JUL-2008 09:44 Category Engine Symptom 497000 Engine Noise Content Issue: Heavy audible knocking heard on start up. Cause: On start up oil pressures can cause the piston cooling jets, (PCJ), to latch into a zero flow condition. Due to hysteresis effect in design the jets do not unlatch until the engine is warm and the oil pressures lower again. During this time with no pressurized oil jet flow to the lower pistons / cylinder bores, overheat and scuff conditions / damage can occur. Action: Replace the engine assy but ensure only engines post serial # ELD00080707063602 are used. This condition will not occur on vehicles post assured Vin# 9A767162. Engines post the info above are fitted with modified PCJ internal springs and this issue is now closed. Regards and I hope that the dealer found the problem Eduardo Quote Link to comment Share on other sites More sharing options...
TJ101 Posted September 10, 2008 Share Posted September 10, 2008 Heard today that the sump pan change is now a recall item Quote Link to comment Share on other sites More sharing options...
BogMonster Posted September 10, 2008 Share Posted September 10, 2008 Heard today that the sump pan change is now a recall item No... where did you hear that? Quote Link to comment Share on other sites More sharing options...
Eduardo Posted September 10, 2008 Share Posted September 10, 2008 I just check the GTR few minutes ago and doesnt appears as a recall, still is a Service Action Bulletin ... Quote Link to comment Share on other sites More sharing options...
JST Posted September 10, 2008 Share Posted September 10, 2008 i hadn't heard it was a recall thing on the sump. Anyone got any pics of undamaged new and undamaged old versions of the sump showing the difference? Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted September 10, 2008 Share Posted September 10, 2008 i hadn't heard it was a recall thing on the sump.Anyone got any pics of undamaged new and undamaged old versions of the sump showing the difference? I was under a puma the other week (with tape measure in hand... ), the sump has a "scalloped" bit cast into it, a nice curve, as opposed to a flat wedge shaped cut-out. no pic, sorry. Quote Link to comment Share on other sites More sharing options...
The Badger Posted September 10, 2008 Author Share Posted September 10, 2008 I was under a puma the other week (with tape measure in hand... ), the sump has a "scalloped" bit cast into it, a nice curve, as opposed to a flat wedge shaped cut-out.no pic, sorry. what he said Quote Link to comment Share on other sites More sharing options...
Eduardo Posted September 10, 2008 Share Posted September 10, 2008 JST I have a pic of the new one and the old one with the scratch. let me found it and I will post it. Regards There is the new one: The old one (just the damaged area, sorry ) Regards Quote Link to comment Share on other sites More sharing options...
TJ101 Posted September 10, 2008 Share Posted September 10, 2008 Another view of the modified one, fitted to mine Quote Link to comment Share on other sites More sharing options...
JST Posted September 10, 2008 Share Posted September 10, 2008 excellent - thank you for the pictures guys Quote Link to comment Share on other sites More sharing options...
scatt Posted September 10, 2008 Share Posted September 10, 2008 Im just waiting to get my defender back after its second transfer and its only done 3500 miles. also on the sump thing i have had mine changed but this was after the prop had made contact with it, and landrover had to see that there had been contact. Quote Link to comment Share on other sites More sharing options...
DaveSIIA Posted September 10, 2008 Share Posted September 10, 2008 Another view of the modified one, fitted to mine Is it my eyesight, or is there a bolt missing on the flange? Quote Link to comment Share on other sites More sharing options...
