landkeeper Posted August 23, 2008 Share Posted August 23, 2008 anyone got a link to where i can check the seriel no of a series gearbox to see what it's from Quote Link to comment Share on other sites More sharing options...
6cyltdi Posted August 23, 2008 Share Posted August 23, 2008 Take a picture from the front and from the offside (drivers side) and post them here...... Cheers.... Quote Link to comment Share on other sites More sharing options...
landkeeper Posted August 23, 2008 Author Share Posted August 23, 2008 [here are the ones i have on the puter it's teeming down outside at the moment i can take more if needs be seriel number is S95102406C cheers Quote Link to comment Share on other sites More sharing options...
chris1965.2A Posted August 23, 2008 Share Posted August 23, 2008 Hi this looks like a series 3 Gearbox due to the clutch arm position, release bearing and gear stick, The spring clip on the filler is off the series 2 2A ?. The suffix C gear box was used in the series 3 and is full synchromesh in forward gears. Quote Link to comment Share on other sites More sharing options...
Phil Hancock Posted September 2, 2008 Share Posted September 2, 2008 Bell housing says S3 4 pot. Oil filler on the top of main box was still used on the MOD S3's, Ribs on reverse gear area of the the main box casing say S3 Suffix B onwards, The horizontal disposition of the reverse gate bracket fixing bolts says S3 suffix D and later. Quote Link to comment Share on other sites More sharing options...
oddballrovers Posted September 3, 2008 Share Posted September 3, 2008 HI Phil please explain this "The horizontal disposition of the reverse gate bracket fixing bolts says S3 suffix D and later. " would like to know what it means Kind regards Ole. Quote Link to comment Share on other sites More sharing options...
Phil Hancock Posted September 3, 2008 Share Posted September 3, 2008 The bolts holding the reverse gate spring loaded plate on to the reverse selector rail fork under the gear lever are horizontal centers on D and on boxes weras the earlier boxes are vertical centers. The rod and gate assembly will fit an earlier box so its only a guide. Quote Link to comment Share on other sites More sharing options...
oddballrovers Posted September 4, 2008 Share Posted September 4, 2008 Hi Phil Thanks a lot, one newer gets to old to learn, I have done a few gearboxes, but newer noticed it so that another info for the soft drive Kind regards Ole. Quote Link to comment Share on other sites More sharing options...
