fender1234 Posted August 23, 2008 Share Posted August 23, 2008 Hi, Ive been taking out my gearbox and transfer box today to get the box reconditioned. but i could not get the box and transfer box apart. So i took the pto cover plate off the back of the transfer box and tryed taking the input gear off. I thought it was supposed to just slide off but it seems to have seized onto the gearbox mainshaft because it will not come off no matter what i try any ideas? thanks Quote Link to comment Share on other sites More sharing options...
Les Henson Posted August 23, 2008 Share Posted August 23, 2008 If the input gear and splines are worn, then it's a lot more difficult to get off. You need to rotate the transfer box gears as you pull it out. Do this by turning one of the drive flanges. Les. Quote Link to comment Share on other sites More sharing options...
fender1234 Posted August 23, 2008 Author Share Posted August 23, 2008 thanks Les i think the splines are worn as there that red paste stuff. so turn the drive flanges and pull it out by hand or will i need some sort of gear puller? regards Quote Link to comment Share on other sites More sharing options...
BogMonster Posted August 23, 2008 Share Posted August 23, 2008 Bit of rocking back and forwards in gear with the cover off might loosen things up a bit, assuming your diffs are still connected Quote Link to comment Share on other sites More sharing options...
